So the voltages do not drop at all. Just the air speed cuts out.
Ok. Does it do this on all settings? How much airflow drop off are we talking? Do you notice anything aside from the lack of air through the ducts when the air drops off and comes back on?
Check to see if when the air flow is going down that air isnt starting to change and come out of two settings instead of the one you have it on. If you snap the throttle all the way open for a second do you notice the air slowing. Or if air is slow do you notice them opening up?
Monday, June 7th, 2010 AT 10:33 AM
