1999 Chevy Monte Carlo
55,340 MILES • 6 CYL • FWD • AUTOMATIC
MBHOWARD
the ant-lock light on the dashboard comes on approximately once or twice a month. Turn the car off & the light will go out. The brake pads were changed approximately 8000 miles ago. This problem was there 6 months before the pads were changed. The brakes work fine when this light comes on. Thank You Marvin
Nov 14, 2009 at 4:10 AM
  • 110,248 POSTS
THe light is indicating a problem within the system. Chances are there is a sensor at one of the wheels going bad. You can have the computer scanned at a nationally recognized parts store to help identify the problem. Most will do it for free.
NOTE: You will have good brakes at all times; however, when the light is on, the ABS will not function.
Nov 17, 2009 at 11:52 PM
