1997 Chevy Monte Carlo Heater Core
1997 CHEVROLET MONTE CARLO
100,000 MILES • 6 CYL • FWD • AUTOMATIC
SHERYLZ
Hi- My car is leaking coolant from an orifice that is up against the firewall on the passenger side. Can you tell me what it is leaking from. My Heater works & blows hot air. My A/C works and blows cold air. Recently replaced Thermostat, and then used a Radiator cleaning solution made by Prestone before I flushed Radiator. However, I didn't flush entire cooling system.
May 22, 2010 at 4:02 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
that would be the heater core location, without seeing in person couldn't say what is leaking exactly. check heater hoses going to heater core, if OK heater core itself may be bad.
May 22, 2010 at 12:57 PM
