1996 Chevrolet Monte Carlo High RPM
GUITARPUNK105
  • 6 POSTS
I drive a 1996 monte Carlo Z34 with 263,000 kilometres on it. I've owned it for three years now, and I've only needed to replace an alternator, belt tensioner, and alternator wiring. Occasionally, my car will just randomly rev much higher than it's supposed to. Sometimes while i drive, it feels like i have cruise control on, but i don't. and when i stop and put the car in neutral or park, the RPMs shoot up to about 3000 or more. Usually the problem goes away if i let the car sit for a few hours, but it's winter now, and it happens very often. so while it was running, i pulled on the cruise control cable and the rpms went down to normal. i thought that was over, but the next day, it wouldn't start. i got the mass air flow sensor cleaned, and the car ran fairly good. but on my way home this evening, the rpms stuck at about 2000. when i stopped the car and put it in park, it shot up to 3000RPM. i slightly touched the gas, and it then went up to the rev limiter, at 4000RPM. i turned it off, but the problem keeps occurring every time i start the car. i'm thinking it could be the O2 sensor, or maybe my cruise control is sticking, but i could use some expert advice here. Thanks.
Feb 27, 2007 at 2:11 PM
CHEVY22
  • 1,375 POSTS
hi
i would check the idle air control valve located on the throttle body , this is a common failure and may be causing you high rpm , also check the throttle body for sticling by hand , see if it is dirty inside , if it it get some throttle body cleaner ,hose it down and wioe clean with a rag
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 27, 2007 at 2:19 PM
Suggested Repair
Check the idle air control valve on the throttle body, a common cause of high RPM. Also inspect the throttle body for sticking and, if dirty, clean it with throttle body cleaner and wipe it with a rag.
Conversation Summary
A 1996 Chevrolet Monte Carlo with high mileage randomly revs too high, sometimes feeling like cruise control is engaged, and idle can jump to about 3000 RPM or the rev limiter in park or neutral. Cleaning the mass airflow sensor helped only briefly. The expert recommends checking the idle air control valve and inspecting and cleaning a dirty or sticking throttle body.
