1996 Chevy Monte Carlo My 96 Monte
1996 CHEVROLET MONTE CARLO
213,000 MILES • 6 CYL • FWD • AUTOMATIC
LIONELL8732
  • 150 POSTS
Hey i got a 1996 monte carlo z34 v6 Dohc Engine 3.4 and i keep getting a code p1441 and i want to how can i get this cleared and what do i have to change. I got another question i just change my spark plugs and my valve cover gaskets and i keep getting a code p0306, is there anything else i should change.
Aug 24, 2010 at 1:39 PM
HMAC300
  • 48,601 POSTS
code P1441 is EVAP purge problem, like maybe the valve is sticking or not working. Your other code isP0306 is an engine misfire. this can be a vacuum leak, fuel filter or bad injector along with low compression bad spark plug or wire. These codes can only be removed by a scanner.
Sep 2, 2010 at 10:52 AM
