Hi susan this code is a cam sensor code.
Your car has a cam sensor in it. It, s job is tell the computer where the camshaft as in what position it is in. This helps the computer how to adjust the timeing and how to mix the fuel. The part about 40. The labor less then a hundred hope this helps, feel free to write back if you need too. Billymac
SPONSORED LINKS
Saturday, June 13th, 2009 AT 6:38 PM
