1996 Chevy Monte Carlo car ran out of gas so replaced fuel
SPOILTONYAMARIE
  • 1996 CHEVROLET MONTE CARLO
Engine Performance problem
1996 Chevy Monte Carlo 6 cyl
the car ran out of gas so the fuel pump replaced and now it starts but idles for a couple seconds but wont stay running can u tell me what the problem is?
Sunday, March 1st, 2009 AT 4:39 PM
TEAG
  • 158 POSTS
It sounds like the fuel pump isnt putting out the right pressure. Get a pressure test gauge and check your fuel pressure. If the pump is new. You might want to go back and check that all the hoses are tight and not leaking. Also check your fuel filter. When you run the tank dry. It sometimes picks up some junk from the bottom of the tank. Could be a clogged fuel filter.
Monday, March 2nd, 2009 AT 11:56 AM
