1984 Chevy Monte Carlo poor running
MASTROFINI1
  • 1984 CHEVROLET MONTE CARLO
  • 6 CYL
  • 48,000 MILES
My name is Scott I recently purchased a 1984 monte carlo with a 3.8 v6. I purchased this vehicle because of the low mileage, and how clean the vehicle was. Here in michigan the rust eats the cars alive! So I purchased this vehicle the old owner said that had sat for over a year since was started last, after jumping the battery the car started, it didnt want to run. It would die, so I had to sit there and feather the gas pedal, eventually after about 2 minutes of working the gas the car would idle. When I went to drive the car home, I noticed when you get the car at about 2000-2500 rpms it would loose power and bogg down like it is being robbed of air? So I removed the air cleaner, I noticed a vacuum line that was disconnected, when I put my finger over the hose the idle would slow down, but still idles high? I do not know alot about carburated cars, any help would greatly be appreciated. Scott
Tuesday, January 1st, 2008 AT 9:39 PM
JOHNYPHANTOM
  • 37 POSTS
First track down where that vacuum hose came off of, also a car that sits for a length of time, the gas can get varnished, you might also want to do a complete tuneup. Also check the vacuum lines closely for cracks or breaks
Friday, February 8th, 2008 AT 9:05 AM
