2000 Chevy Metro
KOACH
  • 2000 CHEVROLET METRO
2000 Chevy Metro
gas guage not working properly what could be the problem
Tuesday, July 20th, 2010 AT 6:32 AM
  • 31,937 POSTS
Hi there,
Normally this is a faulty sender unit in the tank, to check it, with the ignition on, earth the sender power wire and the gauge should go to full deflection, if not the loom or gauge is at fault, this is a test that should be done by a qualified mechanic as you need to make sure that you earth the correct wire for this test.
Mark (mhpautos)
Tuesday, July 20th, 2010 AT 6:38 AM
