1999 Chevy Malibu Brake and CEL Lights
DAYKAT
I have a 99 Malibu LS (Automatic, V6), with approx. 76,000 miles on it. Last month my brake & ABS light began flashing intermittently. I got a complete rear brake job done, this fixed the problem for about 2 weeks, then the light flashed again. The check engine light also began coming on. The mechanic who did my brake job ran a diagnostic on the check engine light and wanted to replace the fuel tank vent valve, the evaporation control canister, and two sensors. The lights were inconsistently coming on, but the car continued to run normally: no rough idling, no brake problems, no increase in temperature. I eventually took it to another mechanic for a second opinion who tightened a loose bolt on one rear brake that was allowing brake fluid to leak (hopefully fixing the brake light problem), and replaced my ignition switch. They claimed the computer had been throwing codes P1665 & P1676, which they said have to do with the Aux controls. Was I fleeced, or should replacing the ignition switch (an expensive part) take care of the problem? This repair was done just this week.
Thanks so much for any input.
Nov 5, 2007 at 6:27 AM
MERLIN2021
  • 17,250 POSTS
p1665= PCM quad driver 3 or EVAP canister vent valve
p1676=PCM quad driver 4 or EVAP canister vent.
as far as the brakes go, must have been a line or bleeder left loose, this is basic stuff!
Is the check engine light out?
Nov 5, 2007 at 7:41 AM
DAYKAT
Thanks for such a prompt reply!
The check engine light actually switched off 2 days before I got the repair done (don't ask me why). It is still off; I hope the repair I got (ignition switch) will keep it turned off. Rrgh.
As for the brake stuff, you're completely right. I'm looking into having the mechanic that worked on the brakes reimburse me for the fix that the current mechanic had to do.
Nov 5, 2007 at 5:31 PM
MERLIN2021
  • 17,250 POSTS
Yea...good call!
Nov 5, 2007 at 6:19 PM
Suggested Repair
The reported codes point to the EVAP canister vent valve or PCM quad drivers, not a confirmed ignition-switch fault. Recheck whether the check engine light stays off and verify the rear brake line or bleeder is tight so fluid is not leaking.
Conversation Summary
A 1999 Chevrolet Malibu had intermittent brake and ABS lights plus a check engine light while otherwise running normally. One shop suggested EVAP vent and sensor parts; another tightened a loose rear brake fitting and replaced the ignition switch after reporting codes P1665 and P1676. The expert identified those codes as PCM quad-driver or EVAP canister vent-valve faults and said the brake issue was a loose line or bleeder. The owner reported the check engine light had already gone out before the switch replacement and planned to seek reimbursement for the brake correction.
