No ability to check dipstick, as no dipstick. Using the inspection plug, I drained about 6 quarts of atf- then replaced 6 quarts, but I still cannot check the fluid level. It was the first change. Just how does a person check the fluid level?
If I pull the pan, will all 9 quarts come out? Or about 6 qts?
signed, lost in sacramento- wm
SPONSORED LINKS
Monday, February 11th, 2008 AT 2:25 PM
