code p0753 malibu lt after flush?
85,000 MILES • 6 CYL • AWD • AUTOMATIC
COWGIRLRIDING
Hi I had my trasmission flushed against my dad's advice and had a small axle leak, i ask to me fixed while they had it there, as i found there was not place to check the transmission fluid after it seemed to shift funny one night. I had it check at the dealership , who told me above what needed to be done. now 4 days later my engin light along with the no traction control light has come on when put in gear, i had the code read above. can you give me info on this. I think they caused it, can i still drive it, and what is i need to have done to fix it, where can i get diagram of transmission so i can fix it. I can' afford the dealer price. I think they are giving me run around , can you please help me.
Jan 31, 2008 at 7:14 AM
SERVICE WRITER
  • 9,123 POSTS
I'm not sure what sequence that hings happened to your car. I f you had an axle leak, then it was a good idea to change the filter while you replacing the seal. How often has it been changed? At least once I would expect. If you ran it with the fluid low, damage can be done. Since you can't check it, you owuldn't know.
I doubt the dealer caused or is repsonible for this.
This is not a d-i-y repair. This needs to be troubleshot by someone with the right equptment to do troubleshooting. A quality scanner will be needed. IT will read freeze frame data when the problem occured and test can be done.
Jan 31, 2008 at 10:33 AM
CHRIS444
I have a. 2005 Chevy Malibu LS and it was low on transmission fluid, It was going in gear hard and then it wouldn't go in gear at all. I charged the filter put Dexron 6 in it takes 7 quarts is what I put in mine since you can t check it like normal cars. But after i did this mine self ,Goes in gear now and shifts like nothing was every wrong with it. So I would do that..I didn't have rev or anything. I think they had wrong fluided in it ..
Mar 28, 2018 at 9:01 AM
CHRIS444
It was low on fluid, I filled it up. go to YouTube and type in your car and what the codes are any video will show up show you step by step that how i fix mine transmission all it was the filter and low on transmission fluid so I did full change and new seal and it works like new no issue
Mar 28, 2018 at 9:04 AM
  • 55,594 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Mar 31, 2018 at 5:09 AM
