Welcome, I agree. I'd check the feed to and from the ignition switch. Check ipc/acc fuse-- 10 amp, left side of dash, use a testlite. The circuit should go hot when you turn on the key. Supplies voltage to instrument cluster.
SPONSORED LINKS
Friday, January 29th, 2021 AT 10:06 AM
