Hi Latonia, your question is rather broad. Could you be little more specific? Can you see it leaking? Where is the smell of fuel strongest?
You may want to inspect the connection between the fuel tank and filler neck and work your way towards the front of the car and replace any leaking component as necessary. Note: If there are any metal lines or metal connections that are leaking, a home mechanic can't repair these so take it to a qualified mechanic to have them repaired immediately.
Good luck.
-thomas-
SPONSORED LINKS
Tuesday, May 25th, 2010 AT 1:12 AM
