HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Malibu
Engine
Symptoms
Not Cranking Over
2000 Chevy Malibu engine gets no fuel
DADDYYUMYUM94
MEMBER
2000 CHEVROLET MALIBU
6 CYL
2WD
AUTOMATIC
150,000 MILES
I've changed the fuel pump but it still won't turn over what should I do next
Sunday, August 1st, 2010 AT 11:44 AM
TOMSHANTY
MEMBER
Check for clogged fuel filter or lines. Also make sure the tank vent lines aren't clogged.
Friday, August 6th, 2010 AT 4:34 AM
RENGLISH8303
MEMBER
Did you find a solution? Im having the same issue in my 04, I have changed the pump and filter.
Monday, August 16th, 2010 AT 1:37 AM
TOMSHANTY
MEMBER
Also, check for a faulty fuel pump relay and faulty fuel injector pressure regulator.
Monday, August 16th, 2010 AT 2:33 AM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
Starter Not Working?
I Have A 2000 Malibu Ls. When I Try To Crank It; It Turned Really Slow Then Started. But After Sitting For A Couple Hours Now It Just Clicks...
Asked by
Sklani16
2000
CHEVROLET MALIBU
VIDEO
Car Not Cranking? Try This | EASY
Instructional repair video
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
Engine Won't Crank Over?
Replaced The Starter And The Engine Still Won, T Turnover.
Asked by
marias5
10 IMAGES
2004
CHEVROLET MALIBU
99 Malibu Will Turn Over But Not Start
Was Performing Very Well On City And Freeway, Stopped To Visit A Client For 2 Hours And The Car Would Not Start. No Forewarning Symptoms....
Asked by
gregauto
1999
CHEVROLET MALIBU
Car Engine Turns Over But Does Not Crank
Drove Car Fine For Last Four Months No Problems Except It Stalls Or Cuts Off At Times While Sitting At A Red Light. I Tried To Crank One...
Asked by
Anthonyt101
1 ANSWER
1979
CHEVROLET MALIBU
Clicking Sound And Wont Crank
Clicking Sound, But No Crank. I Had The Starter Checked And The Starter Is Okay. What Else Can It Be?
Asked by
mikec72
1 IMAGE
2002
CHEVROLET MALIBU
VIEW MORE
Battery Replacement Dodge
Battery Replacement Guide
