2000 Chevy Malibu car stalls while driving
TYLERHUNT
  • 2000 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 133,000 MILES
My car wont start after it stalls while driving. On less its left for a few hours and has a hard time starting takes two or three tries. Changed the fuel pump and the ign mod is there any thing that wont make my car do this
thanks
tyler
Sunday, May 24th, 2009 AT 1:25 AM
RHALL77
  • 3,361 POSTS
Check fuel pressre and spark and see what you are losing when it doesnt start.
Tuesday, May 26th, 2009 AT 8:20 PM
TYLERHUNT
I checked both and both are fine it seems like something is overheating any ideas
Tuesday, May 26th, 2009 AT 10:58 PM
RHALL77
  • 3,361 POSTS
What about injector pulse. Did you check that?
Wednesday, May 27th, 2009 AT 7:44 AM
TYLERHUNT
No I never checked that I was told that it might be the crankshaft sensor so I changed that the car started for about a 45 seconds and then stalled agian and would not start after. How would I go about checking the pulse
Wednesday, May 27th, 2009 AT 12:46 PM
RHALL77
  • 3,361 POSTS
You would need to obtain a set of noid light to test the voltage at the injectors. Same concept as checking spark
Wednesday, May 27th, 2009 AT 1:36 PM
TYLERHUNT
I had a tech check it and they said it was working lots of spark lots of fuel psi he said that is sounded like it was an electrical problem any ideas
Wednesday, May 27th, 2009 AT 4:43 PM
SAMMARTIN1980
My car did the same thing. After spending hundreds of dollars on it I found out it was the mass air sensor. If that helps any.
Saturday, July 4th, 2009 AT 7:06 AM
Related Engine Stall While Driving Content
Code Read Retrieval/Clear Chevrolet
VIDEO
