1999 Chevy Malibu 99 malibu egr reoccurring problem
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
MALIBOOHOO
I keep getting the insufficient egr flow code. I have replaced the egr valve. I have great vacuum at the manifold. I have cleaned the maf sensor. I have had the code cleared and the car will run fine and get great mileage then the light will come back on a few days later and then the mileage goes bad. The car runs fine! I am out of ideas. I have also tried the Seafoam additive and a new air filter. This is driving me nuts!!!!
Dec 8, 2008 at 4:23 AM
RHALL77
  • 3,361 POSTS
have you checked to see what the new code is. let me know what it is, and ill see what i can do to help you. one tip of advise do not clean a maf sensor. usually they go bad after you clean them.
Dec 8, 2008 at 11:11 AM
MALIBOOHOO
I just had it checked again tonight and the code is the same. I had the kid clear the code and everything is fine again. I wrote down the mileage this time just to see how many miles I'll get before it comes on again.
Dec 8, 2008 at 11:37 AM
RHALL77
  • 3,361 POSTS
is it possible to get the code number from you
Dec 10, 2008 at 9:10 AM
