HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Malibu
Engine
Symptoms
Idle Rough
1998 Chevy Malibu Rough idle
BUGED66
MEMBER
1998 CHEVROLET MALIBU
6 CYL
FWD
AUTOMATIC
140,000 MILES
What would make the idle very rough. It bounces between 500 rpm and 1300 rpm. It does this in park.
Wednesday, July 28th, 2010 AT 11:59 PM
MECHANIC
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
SPONSORED LINKS
Thursday, July 29th, 2010 AT 12:05 AM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
98 Malibu 2.4 Rough Idle
Approx 99,000 Miles. Car Just Started Rough Idle / Miss At A Stop Sign And Or In The Driveway. Happens When Cold Or Warm. Almost Want To...
Asked by
ri01rod2
1998
CHEVROLET MALIBU
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
1998 Chevy Malibu Rough Idle
My Car Runs Fine Cold, And Starts Imediately When It's Cold, But When It Warms Up Becomes Harder To Start And Starts To Idle Rough But It...
Asked by
NFSINSANE
1 ANSWER
1998
CHEVROLET MALIBU
Engine Idles Rough?
My Friend Has A Malibu And He Knows Nothing A Bought Cars. The Problem I Need Help With Is It Starts Hard And Has A Miss While Idling...
Asked by
nitro135
1 ANSWER
1998
CHEVROLET MALIBU
2007 Chevrolet Malibu Rough Idle
Hi And Thanks In Advance For Your Help! I Recently Had A Used Transmission Put In My Car And Had An O2 Sensor Wire Replaced. When The Guy...
Asked by
kristinawhite09
2007
CHEVROLET MALIBU
1999 Chevy Malibu Adding Gas Causes Rough Idle
When Girlfriend Pumps Gas To Over 3/4 Full. The Car Has A Heck Of A Time Restarting At The Gas Station. After A While It Starts With A Rough...
Asked by
wekjo
1 ANSWER
1999
CHEVROLET MALIBU
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
Vacuum Leak
Online car repair manuals
