2000 Chevy Lumina Blown Head Gasket
TLWARNER
I have a 2000 Chevy Lumina, 115,000 miles, with a blown headgasget. The mechanic wants to charge $1300 to replace the gasget (at the minimum, due to he doesn't know if the heads are warped).
I found an engine (3.1 6 cyl) at a junkyard for $300. How long should it take to change out the engine?
What should I look for when purchasing a used engine?
Is it a better idea to change the engine instead of having the repairs done? What will save me the most money?
This car is my son's and he needs it for commuting to college.
Mar 3, 2007 at 6:00 AM
CHEVY22
  • 1,375 POSTS
hi
the one problem you may find is the junkyard engine may not even run and if it does how long will it last , and even if it did it would be reccomended to replace belts , hoses , things like that , and lets say you put it in and i didnt work , you would have to pay to r&r it again,
1300,00 for a head gasket on that engine is way too high ,
i would like to recommend either having it repaired (by someone else) or look at a reman engine from jasper or gm , they are cheaper than you think , and your son is driving it
jasper has a website i think its jasperengines.com and i think they have pricing on the page and a good nationwide warrany as the gm reman will have the same
thanks
jim
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 3, 2007 at 6:08 AM
Suggested Repair
Get a second opinion on the head gasket repair, since the $1300 quote is considered high. Prefer a warranted remanufactured Jasper or GM engine over an untested junkyard engine, which may not run or last and would still need belts, hoses, and related parts.
Conversation Summary
The owner of a 2000 Chevy Lumina with a blown head gasket was quoted at least $1300 and asked whether a $300 junkyard 3.1 engine would save money and what to check before buying. The expert said the quote is too high, a junkyard engine may not run or last, and a failed swap would mean paying to remove and reinstall it again. They recommended another shop for the gasket repair or a remanufactured Jasper or GM engine with a nationwide warranty, especially because the car is used for college commuting.
