Replacing the radiator did it solved the overheating problem?
Did the CEL came On or flashes?
When was the last major tune-up on it? If so what was replaced and what type of adjustment was made?
Okay-You need to check the battery is it run down all that cranking you'll be doing if so charge it up and get it to 12.4 to 12.8 as possible.
If battery okay-get inside and turn key to On position-do you hear the fuel pump? I need to know this before we continue. We gonna take this thing step by step.
SPONSORED LINKS
Sunday, October 21st, 2007 AT 11:44 PM
