how do i remove brake drums from the rear wheels of a 2000 chevy lumina
Oct 7, 2007 at 1:25 AM
MERLIN2021
✓Experienced Mechanic
It's tricky, I use a pick, it's a small tin pick with a 90 degree bend, push the adjuster away from the starwheel and back off till the drum is loose enough to pull off!
