How do you replace the thermostat and where is it located.
Dec 2, 2008 at 2:28 AM
DOCFIXIT
✓Experienced Mechanic
Follow top rad. hose to block there it is in that housing. Drain coolant, unbolt. clen off gasket replace and fill. to the left side top engine see a tube and a small bleeder valve open this to remove air.
Dec 2, 2008 at 2:34 AM
