1999 Chevy Lumina Whining from belt under hood
107,120 MILES • 6 CYL • FWD • AUTOMATIC
LOCKER125
I have been getting this whining "eehh" sound coming from under the hood it appears to be coming from the timing belt. The sound gets louder and more noticeable as I press on the accelerator.
Strange but sometimes it will go away and come back. A mechanic said he didn't hear anything because it was not doing it that day and said there is a tension adjuster that could be doing that.
Should I have the belt replaced? It is about four years old.
Is lubricating the belt recommended?
Dec 14, 2008 at 9:21 AM
JAMES W.
  • 2,394 POSTS
The last thing you want to do is try to lube a belt. This will only make a bad situation worse. Look at it as for belt's way of it telling you i'm tired, change me. A $40 dollar belt now, can save you hundreds down the road. Hope this helps.
Dec 14, 2008 at 10:44 AM
