1999 Chevy Lumina Mass Airflow Sensor
1999 CHEVROLET LUMINA
125,000 MILES • V8 • FWD • AUTOMATIC
CARLYPUTMAN
The check engine light was on, the car began to cut out, and the fuel efficiency was poor. We had the diagnostic computer check, and the code for a mass airflow sensor came up. We replaced the mass airflow sensor. The check engine light went off and the car ran perfectly for about 4 days. We warranteed out the MAF for a new one, thinking we may have gotten a faulty part. This worked great for about two weeks, when the check engine light came back on and the fuel efficiency is poor again. Is there a problem related to the MAF that is causing the code to come up again? Any suggestions would be great.
Thanks,
Carly
Oct 2, 2010 at 6:20 PM
NICKHEADZ34
  • 62 POSTS
always change the filter and clean the duct when you do a maf otherwise you could foul the sensor again. these are delicate items. see if you can get one more from the store. if not crc makes a maf cleaner you could try that before shelling out for more parts.but again. very delicate sensor to mess with
Oct 2, 2010 at 6:26 PM
NICKHEADZ34
  • 62 POSTS
maf is mass airflow.
Oct 2, 2010 at 6:28 PM
