1998 Chevy Lumina Will NOT idle
1998 CHEVROLET LUMINA
181,000 MILES • 6 CYL • FWD • AUTOMATIC
JAYB0GG
  • 5 POSTS
I have a 1998 Chevrolet Lumina. It has a 3100 and it just refuses to idle. In the mornings it will run fine, or after it hasn't been driven for a while. But as soon as it gets warm or it refuses to idle. I went about it the wrong way and started throwing money into it randomly. It has a NEW: EGR valve, MAP sensor, IAC valve, TPS, PCV valve, plugs and wires. I was told it could be a leak in a vacuum but I have checked a few times and really found nothing. It has gotten so bad that you can't even go through the window at a bank or fast food place with out it bogging down and back up. When it does this it drops from 300 to 2000 rpm, and if you let it 99% of the time it will shut off. It drives like a dream. It has just gotten so annoying I don't like to drive it. It is easily provoked at idle by a heavy electrical load as well, Rear defrost of automatic headlights kicking on will usually make it happen if its not happening all ready.
Jan 2, 2010 at 1:13 AM
  • 110,244 POSTS
It sounds like you have already replaced the items that would cause it. I will say that the 3.1L V6 is common to have intake leaks. Also, I want you to have the alternator checked. Since you mentioned the electrical situation, I question the alt.
Let me know what you find.
Jan 19, 2010 at 5:10 AM
