1998 Chevy Lumina thermostat
BOB0001
  • 1998 CHEVROLET LUMINA
1998 Chevy Lumina 6 cyl
how do I replace the thermostat
Sunday, April 19th, 2009 AT 9:18 AM
  • 109,896 POSTS
If you follow the upper rad hose to the engine, it will lead you to the t-stat housing. Drain the coolant from the radiator, remove the upper hose, and unbolt the housing. The t-stat is under the housing. Pay attention to the direction the t-stat is pointing so you can replace it the same way. Just reverse the procedure to replace.
Friday, June 21st, 2019 AT 3:04 PM
