1998 Chevy Lumina Servine Engine Light Stays On
TOMMY.HAYGOOD
  • 1998 CHEVROLET LUMINA
  • 6 CYL
  • 230,000 MILES
I purchased a used Lumina for a work car. The car starts and runs fine. The Service Light comes on and the change oil light also comes on and goes off.
I plan to take it in for diagnostic check, but I was wondering if it was anything that I could do?
Wednesday, October 14th, 2009 AT 9:51 AM
DOUG RODRIGUES
  • 11 POSTS
Getting the trouble code causing the Check Engine light to stay on would be a good start. The repair manual will tell you which two contacts to bridge on the test outlet to get the codes, or you can simply stop by a parts store that does that for free.
Sunday, October 18th, 2009 AT 11:28 AM
CRZYDRVR
  • 432 POSTS
Second generation On Board Diagnostics you CANNOT bridge these contacts to flash the codes from the PCM. However most parts stores do have a code reader that will give you the code. But remember that the code isn't always going to be correct or allow you to graph any components to see if another failed part is giving another false readings.
Thursday, October 22nd, 2009 AT 7:46 PM
