1997 Chevy Lumina security light is on
CHARMONSR
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 103,000 MILES
I try to start the car and security lite is blinking
Tuesday, May 4th, 2010 AT 5:47 AM
BMRFIXIT
  • 19,053 POSTS
Your vehicle is equipped with Personal Automotive Security System (PASS-Key II(R)).
This security system is designed to prevent vehicle theft by disabling fuel system and starter unless an ignition key with a specific electrical resistance is used in the ignition key lock cylinder. PASS-Key II(R) system operates using sensing contacts, which are located in the ignition key lock cylinder. These contact a resistor pellet located in the ignition key. When lock is rotated, battery voltage is applied through appropriate fuse and resistor pellet to theft deterrent module (except Century), or body control module (Century). Pellet resistance is then compared with programmed value in the theft deterrent module or Body Control Module (BCM).
System components include ignition key, ignition key lock cylinder, theft deterrent module (except Century) or BCM (Century), theft deterrent relay and Powertrain Control Module (PCM). The PASS-Key II(R) system can also be supplied as a special equipment option on some vehicles
youtube is full of video on how to bypass the system
should check it out
Saturday, May 8th, 2010 AT 6:13 AM
