I took my car into Valvoline recently because my "service engine soon" light came on (and its still on). They hooked up their little car computer thing, and what they told me was that it had something to do with gas vapors. They said there might be a pin hole leak from the gas cap. I talked to someone else who said that if my gas cap isnt on tight enough, even the smallest bit of gas vapor can escape and cause this. She also said that after making sure the gas cap is on securely, that the computer sys will reset itself in about 2 weeks. Is this true? And will this affect the car in terms of passing inspection?
Nov 7, 2009 at 4:33 PM
