1997 Chevy Lumina Misfire in cylinder 2
GEODEL48
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 17,956 MILES
I recently had a tune up, oil change and new radiator put in the car. This week the check engine came on. I took the car to a mechanic and his computer showed "random misfire". He checked all the spark plugs and wires, and said all was fine. Another check on the computer showed "misfire in cylinder 2" so he changed the ignition coil. When I drive for an hour or so and the car gets hot, I get home park the car, and go out 30 - 60 minutes later, start the car and it seems flooded to where I have to hold my foot down on the gas pedal to clear it out. What can this be? Any help you can give me is greatly appreciated. I am totally broke right now and just can't afford to donate right now, but, I will come back to the site when I get my ss check in the beginning of the month. Thank you.
Saturday, July 17th, 2010 AT 3:31 PM
P0300 Random misfire normally caused by vacuum leak and bad fuel fuel
Other causes below:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve
Saturday, July 17th, 2010 AT 4:29 PM
