1997 Chevy Lumina EGR Valve
BAKE2009
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • 15,200 MILES
First code was miss in cyl. Five. Since wires had over 100,000 miles on them, I replaced them. Reset comp. Then I got code for heater malfunction on o2 sensor after conv. Replaced sensor & cleared light. Third time it was code 401, low recirc exh. Gas. Replaced EGR, drove car around for about 25 milesor so. Light hasn't gone off. Do I need more driving time or is there another problem. Since there is 152'000 miles on car, I just figured those parts needed replaced.I have two cards with money left on them with $8.30 on them.I don't use cards on the internet.I appreciate any help I can get.I'm out of work & need to pass emmisions test. Thank you for your time.
Saturday, January 10th, 2009 AT 5:09 PM
  • 109,885 POSTS
Have the light reset. Most parts stores will do it for free.
Saturday, January 10th, 2009 AT 8:20 PM
KIRKWA
  • 8 POSTS
Pull the ECM fuse, or disconnect the battery for 3 minutes to reset the check engine light.
Wednesday, February 11th, 2009 AT 5:32 AM
