1997 Chevy Lumina AC blows regular air, but no cold air
1997 CHEVROLET LUMINA
147,800 MILES • 6 CYL • FWD • AUTOMATIC
ZODIACDUDE
The heating in my car works, but not the A/C. I took it in a few years ago to have it checked out, and Firestone said that they tested it and it worked ok for a little while, but then it died out. They said I didnt need a whole new A/C unit, but I needed some part that I can't remember the name of now. Any idea what part that would be?
Nov 8, 2009 at 12:16 AM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
AC system is a complicated and easy at the same time
1st you need to know if the system holding in the refrigerant or if its leaking
if leaking have to check and find the leak and repair the area
many methods can be used to find the leak ,this is some
Bubble Solution Detector
This is a solution applied externally at suspected leak points. Leaking refrigerant will cause the detector to form bubbles and foam. A soap and water solution also works well.
Dye Solution
This is a colored solution that may be introduced into the A/C system. The dye will show up and color components at leak points. Some manufacturers offer refrigerant containing a Red dye. This dye-containing refrigerant is installed by normal charging procedures. Other dye solutions are visible with a Black light only.
Electronic Detector
This instrument will draw in any leaking refrigerant through a test probe, and then sound an alarm or create a flashing light if refrigerant is found. It is the most sensitive of the leak detectors used
if system if holding and no leak
know you have to check if the AC compressor coming on and what you have for pressure on low and high side
need to use a set of manifold gauges
if this part of the system check OK
know we move on to the HVAC box and the blend operation
and have to check if the blend door operating and the actuator function
Nov 8, 2009 at 7:36 AM
