1996 Chevy Lumina tranny
JMOTZKO
  • 1996 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 80,000 MILES
My lumina has less than 80k. It shifts gears up @ 1200 rpm, and doesnt downshift till like 500 rpm. I was told by a shady mechanic that I need a new transmission. But I have put well over 5000 miles on it and still runs the same. It runs ok briefly every so often. Another gentelman told that there is a electronic shift module that could have burnt out. To me it seems like an electric problem, but I dont know enough about it to say one way or another. Is there any electronic parts on my tranny, or do I need a new one?
Friday, January 23rd, 2009 AT 9:22 AM
  • 109,885 POSTS
Hi:
There are electric shift solenoids that are located on the valve body. Yes, they could cause this problem. They are not hard to replace. If you have replaced a trans filter, you could do this too. Also, if you decide to do it, make sure there isn't a broken wire going to the solenoid. They can break internally and only make contact at times.
Friday, January 23rd, 2009 AT 7:21 PM
