HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine
Symptoms
Misfire
SPONSORED LINKS
1996 Chevy Lumina motor
MARQUIS4X4
MEMBER
1996 CHEVROLET LUMINA
6 CYL
FWD
AUTOMATIC
100,000 MILES
My car starts and starts rattle and has no power I hooked it up and it said multiple misfire and random misfire
Tuesday, May 12th, 2009 AT 8:17 PM
LEGITIMATE007
MECHANIC
Your gonna have to start with the basics, check/change plugs and wires. Spark
SPONSORED LINKS
Tuesday, May 12th, 2009 AT 8:41 PM
LEGITIMATE007
MECHANIC
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
this will show you how to check for consistant spark
Tuesday, May 12th, 2009 AT 8:42 PM
LEGITIMATE007
MECHANIC
You may not need to check fuel pressure, but for good measure and future reference, here is a link to a video that will show you how
Tuesday, May 12th, 2009 AT 8:44 PM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
1996 Chevy Lumina Random Missfire Codes/poor Mileage
I Suspect A Fuel Issue, But After Testing Pressure, The Regulator, Filter And Pump, I Am At A Loss. The Car Send Random Missfire Codes...
Asked by
rblumenthal
1 ANSWER
1996
CHEVROLET LUMINA
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
Chugging On A 1996 Chevy Lumina 4 Door 6-cyl 164,000...
I Am Having A Chugging Problem On My 1996 Chevy Lumina 4 Door 6-cyl 164,000 Mileage. It Was Fine Until Last Sunday. It Has Been Cold...
Asked by
JMoney13
1996
CHEVROLET LUMINA
1990 Chevy Lumina Egr Code Engine Miss
Engine Runs Fine Until Warm With No Miss. After Engine Is Warm, Engine Misses At Idle. Drops Number Three Cylinder. Plug Wire Good...
Asked by
bobpick1962
1 ANSWER
1990
CHEVROLET LUMINA
1994 Chevy Lumina Engine Miss
Had Tune-up Done. Plugs, Wires, Oxgen Sensor, Fuel Filter, Etc. At Cold Idle Engine Misses But Not Badly. Starts Good But...
Asked by
David Fisher
1994
CHEVROLET LUMINA
Miss Firing When Mashing The Gas Slightly Above 1500...
1998 Chevy Lumina Car 3.1 It Started When My Son Put A Amp. In His Car Put The Hot Wire On Fuse Box Above The Ecm & Shorted The Hot Wire...
Asked by
Big Jim
1998
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
How to Repair an Engine Cylinder Misfire
Online car repair manuals
