1996 Chevy Lumina CAR REPAIR
SEXXYANGIE
  • 1996 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 25,000 MILES
My hasnt run hot but the temo. Hand moves all the way over and I pull over until it cools.I just had a tension pulley put in. After the car gets hot and I take my foot off the gas it shuts off. It has to cool before it will crank back up what could that be and can I be repaired inexpensivly?
Wednesday, May 28th, 2008 AT 12:04 AM
LEGITIMATE007
  • 5,121 POSTS
Sounds like two things. Check the coolant temperature sensor, that may fix the whole problem but if not then you need to check your crankshaft position sensor. The coolant sensor is a very simple task, its right in the block by the coolant inlet. Also the crank position sensor will be right next to the crankshaft in the timingchain cover, should be able to do both yourself. And I also recommend buying the parts from our discount auto parts center. Just click the link below and on the site menu click "discount autoparts" High Quality Parts for cheap prices, awesome site.
Wednesday, May 28th, 2008 AT 12:11 AM
