The car starts well when cold but soon the engine has a slight back and forth shake. When I increase rpm to above 1,500 it stops shaking. Sometimes white smoke comes out at higher rpm. When the engine is hot, the car is difficult to start and I have to pump gas to get it started and then it will idle rough for a few minutes and then shut off.
I took it to a dealership and they could not pull out any codes. The fuel pressure when the ignition is on(engine not running ) is 43 PSI and at idle is 40 PSI. The vacuum is 15 PSI. Compression test is within normal limits.
However, the engine runs rich and there's gasoline in the intake manifold. What could be the reason why gasoline is in the intake manifold?
SPONSORED LINKS
Wednesday, June 24th, 2009 AT 1:54 PM
