1995 Chevy Lumina fuse box
FLOWERCEL
  • 1995 CHEVROLET LUMINA
Electrical problem
1995 Chevy Lumina Engine Size unknown Two Wheel Drive Automatic 120000 miles
what is the name of the box, under the hood, near the battery, attached to the wheel well ans contains fuses? The thing that I need to connect with a wire to the battery is broke! When I try to start the car it does nothing! Weird - I do have parking lights though!
Saturday, February 23rd, 2008 AT 1:03 PM
MASTERTECHTIM
  • 4,749 POSTS
Thats the under hood junction block. Or under hood fuse box. That fat red wire going to it is very important.
Saturday, February 23rd, 2008 AT 1:20 PM
FLOWERCEL
  • 9 POSTS
Is the whole box replacable? The thing that looks like a prong to a sparkplug broke off the main fuse box part!
Saturday, February 23rd, 2008 AT 1:25 PM
MASTERTECHTIM
  • 4,749 POSTS
That is a good question. I dont have a answer. If I remember right, I dont think it is plugged in. Its part of the wiring harness. Is it possible to drill a hole through it and use a small nut and bolt. Thats probably what I would do. Either that or I would weld a bolt to it.
Saturday, February 23rd, 2008 AT 1:30 PM
FLOWERCEL
  • 9 POSTS
I am going to send a pic (hopefully) of my issue
be right back
Saturday, February 23rd, 2008 AT 1:38 PM
FLOWERCEL
  • 9 POSTS
As you can see I tried to use a couple cable ties to hold the parts together because the box is plastic - where would I weld a bolt?
Saturday, February 23rd, 2008 AT 1:49 PM
FLOWERCEL
  • 9 POSTS
Can I email you the pics?
Saturday, February 23rd, 2008 AT 1:57 PM
FLOWERCEL
  • 9 POSTS
Can I bypass this box in any way?
Saturday, February 23rd, 2008 AT 3:12 PM
MASTERTECHTIM
  • 4,749 POSTS
There are several ways to fix this problem. These studs are very popular for melting. Due to the net loosening on the stud. If I had the car in front of me it would be a lot easier. Is the stud loose? If you take off the nut what are you left with? If I am seeing correctly the stud is broken fron the metal part of the fuse box. The metal piece sends the power to everything in the box. Is it possible for you to take out the broken stud then install a nut and bolt to secure the cable to the fuse box?**You will first need to use sand paper and make sure the cable is clean, so we dont have this problem again. That box comes out pretty easy too. Disconnect battery and the 10 mm nuts holding it in and lift it up and get a better look at what I am talking about. In worse case scenario you can go to any salvage yard and cut one out from a junk car and then cut yours out and solder the wires back together. I dont think there are too many wires in there.
Saturday, February 23rd, 2008 AT 3:26 PM
FLOWERCEL
  • 9 POSTS
Thanks for the first question answered - we will try your suggestion but here is another possible problem. My dh thinks that the anti theft code needs reset since he unplugged the battery from this box - any sugeestions?
Saturday, February 23rd, 2008 AT 3:40 PM
MASTERTECHTIM
  • 4,749 POSTS
No resetting required.
Saturday, February 23rd, 2008 AT 4:06 PM
Related General Content
