HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine
Symptoms
Stall at Idle
1995 Chevy Lumina
KIMHARMIC
MEMBER
1995 CHEVROLET LUMINA
Electrical problem
1995 Chevy Lumina 6 cyl Automatic
Car will not turn over with key. Jump at starter, starts then dies.
Monday, February 22nd, 2010 AT 3:18 PM
MECHANIC
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
SPONSORED LINKS
Monday, February 22nd, 2010 AT 7:06 PM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
1995 Chevy Lumina Hard To Start Then Stalls And Won'...
1995 Cevy Lumina Starts When Cold After I Turn It Over A Few Times. And Wants To Stall On Me. It Warms Up And It Runs Alittle Better But...
Asked by
Rick1959
1995
CHEVROLET LUMINA
GUIDE
Engine Stalls After Dead or New Battery
So you installed a new battery and now the engine stalls? You have done nothing wrong because believe it or not this is normal. The engine computer has a learning cycle...
Why Does My Chevy Lumina Die When I Put It In Gear Or...
It Dies At The Changing Of Gears I.E. Reverse To Forward, And Sometimes When You Stop At A Stop Sign And Are Still In Gear.
Asked by
mike luckey
1 IMAGE
1991
CHEVROLET LUMINA
Car Starts And Idles But Cuts Out And Dies When I...
I Have Had It Scanned On A Computer, The Only Code Came Up Was An O2 Sensor. I Have Changed The Crank Shaft Position Sensor, The Throttle...
Asked by
justin2
1990
CHEVROLET LUMINA
1992 Chevy Lumina Stalls When Put In To Gear
Ok So I Have A 92 Lumina Wht About 86,000 Miles On It. I Was Driving It Around Today For Awhile And I Get To My Off Ramp, And Slow And...
Asked by
Driver101
1992
CHEVROLET LUMINA
1993 Chevy Lumina Car Will Not Idle
Engine Performance Problem 1993 Chevy Lumina 6 Cyl Front Wheel Drive Automatic My 93 Chevy Lumina Will Not Idle, When I Crank It...
Asked by
06ctd
1993
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
Stalls at Idle
How to Replace Serpentine Belt Toyota Prius
Spark Plug Replacement Ford Explorer 4.6L V8
Online car repair manuals
