1994 Chevy Lumina No cold starting
LILYMAN
  • 1994 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 19,500 MILES
When the tempeture is below 35 It has trouble starting. When the key is turned on to start. The fuel pump runs for a few seconds but it will not start each time I try the fuel pump runs for a longer time. But it still won't start.
Saturday, January 24th, 2009 AT 8:22 AM
MERLIN2021
  • 17,250 POSTS
Check your ECT(engine coolant temp) sensor.
Saturday, January 24th, 2009 AT 8:24 AM
JDL
  • 16,098 POSTS
Hello, have you done any basic tests? Have a helper crank it while you check for spark at the plugs. If you have spark everywhere, check fuel pressure. Can you check for codes? Your obd1
After rereading your post, Merlin2021 has a good idea.
Saturday, January 24th, 2009 AT 8:31 AM
