1994 Chevy Lumina Front Wheel Drive Automatic 138000 miles
My Lumina APV engine size 3.8 is running on low voltage. It is running between 10-12 on the voltage reading on the dash. I have replaced the battery and the alternator. Before the alternator, it would run to 0 amps and the battery would die in about 10 min of driving. I have driven the car 3 times since the alternator was replaced--each time for about 10 min, and the voltage is staying right at about 10-12 amps. I know this probably isn't where it needs to be. Any thoughts on what could be causing the problem? Before the alternator was replace, and the volts dropped to 8, the ABS lights would also come on. Need to know what to look into next. Thanks
SPONSORED LINKS
Monday, June 21st, 2010 AT 3:11 PM
