HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine
Symptoms
Stall at Idle
SPONSORED LINKS
1993 Chevy Lumina fuel system
DOGG69
MEMBER
1993 CHEVROLET LUMINA
6 CYL
FWD
AUTOMATIC
10,000 MILES
Gass keeps backing up into the air brearther. The car will run for a hour good then it starts to spit n; supper n stall at stop sighs replace 4 censoners please help thank you
SPONSORED LINKS
Friday, March 19th, 2010 AT 11:59 AM
LEGITIMATE007
MECHANIC
Change the pcv valve, then check fuel pressure.
Saturday, March 20th, 2010 AT 11:36 AM
LEGITIMATE007
MECHANIC
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
SPONSORED LINKS
Saturday, March 20th, 2010 AT 11:37 AM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
1993 Chevy Lumina Car Will Not Idle
Engine Performance Problem 1993 Chevy Lumina 6 Cyl Front Wheel Drive Automatic My 93 Chevy Lumina Will Not Idle, When I Crank It...
Asked by
06ctd
1993
CHEVROLET LUMINA
GUIDE
Engine Stalls After Dead or New Battery
So you installed a new battery and now the engine stalls? You have done nothing wrong because believe it or not this is normal. The engine computer has a learning cycle...
1993 Chevy Lumina 93 Lumina Won't Idle
I Have A 1993 Lumina Euro Sedan. 3.1 V-6. 118,000 Mls. It Will Not Idle And Runs Very Rough When Cold And Then Smooths Out As It Warms Up. I...
Asked by
backwoods4ever
1 ANSWER
1993
CHEVROLET LUMINA
Why Does My Chevy Lumina Die When I Put It In Gear Or...
It Dies At The Changing Of Gears I.E. Reverse To Forward, And Sometimes When You Stop At A Stop Sign And Are Still In Gear.
Asked by
mike luckey
1 IMAGE
1991
CHEVROLET LUMINA
Car Starts And Idles But Cuts Out And Dies When I...
I Have Had It Scanned On A Computer, The Only Code Came Up Was An O2 Sensor. I Have Changed The Crank Shaft Position Sensor, The Throttle...
Asked by
justin2
1990
CHEVROLET LUMINA
1992 Chevy Lumina Stalls When Put In To Gear
Ok So I Have A 92 Lumina Wht About 86,000 Miles On It. I Was Driving It Around Today For Awhile And I Get To My Off Ramp, And Slow And...
Asked by
Driver101
1992
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
Stalls at Idle
Change the Spark Plugs 6.0L V8
Oil Change and Oil Filter Replacement VW
Online car repair manuals
