1992 Chevy Lumina Transmission downshifts rough
380,000 MILES • 6 CYL • FWD • AUTOMATIC
CGIN59
After you revive yourself on the subject of how many miles are on this car, I'll give you a short history. This car has been well taken care of and still runs like new. I change the transmission fluid about every 10k to 30k miles. It is the original tranny with no repairs ever. It down shifts roughly, almost with a kick usually from 3rd to second or second to first. It's been doing that periodically for the last 200,000 miles. Changing the fluid did not fix the problem. The most obvious answer is probably it needs some repair after 380,000 mile, however, I am skeptical. Other than the rough downshift, it has operated flawlessly all these years and still does. Could it need a minor adjustment to the shifting belt(s)? or a sticking solenoid? It does this about 50% of the time. Otherwise it runs flawless.
Dec 31, 2008 at 3:56 AM
JAMES W.
  • 2,394 POSTS
380K, that's says a lot about TLC. Trees don't that long. Anyway, on to your shifting. Low pump pressure will cause the problem you describe, and considering the mileage, I would have it checked. It may be the pressure regulator is a little tired. With low pump pressure the shift overlap isn't as smooth as it should be. Also, I commend you on getting that kind of mileage out of "any" car.
Dec 31, 2008 at 12:59 PM
