1992 Chevy Lumina Sputters and dies after about 10 miles
199,340 MILES • 6 CYL • FWD • AUTOMATIC
TETRA021
  • 15 POSTS
I have a 1992 Lumina APV 3.1 that after it reaches normal operating temperature and I drive it around for a bit, It will sputter and stall out. If I wait a few minutes it will start back up but quickly go back to sputtering. It will run fine with absolutely no problems while cold. I do have a few Ideas for the problem such as fuel filter(needs replacement anyway) and spark plugs. It was sitting for 4 years before I got it btw and had half a tank of old gas. I also have the feeling that the catalytic converter may be plugged.
May 20, 2010 at 9:06 AM
  • 75,988 POSTS
Hi tetra021, Welcome to 2carpros and TY for the donation
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 20, 2010 at 12:03 PM
