1992 Chevy Lumina rattle underneath and engine miss
TNMAN6978ZH
  • 1992 CHEVROLET LUMINA
  • 6 CYL
  • 87,000 MILES
My 1992 3.1 has an engine miss and rattle coming from unerneath the car. It was running fine when one day I started it up and it had a miss. There is a rattle coming from underneath since I bought it. It has slowly gotten worse. I changed plugs and wire, with no difference. It seems like the exhaust has gotten louder since the miss in the engine. If it is the cat, how can I tell for sure? No check engine light on. Any clue? Thanks!
Sunday, July 11th, 2010 AT 7:44 AM
JALOPYPAPA
  • 467 POSTS
Someone needs to look the exhaust system over carefully. The ceramic substrate material inside the cat can break and rattle when you shake it, in which case you need a new cat. But it sounds like you have a hole or maybe a loose connection somewhere, which could cause a rattle.
Monday, July 12th, 2010 AT 3:34 PM
