Brakes problem
1992 Chevy Lumina 6 cyl Front Wheel Drive Automatic
how do you change rear brake pads on a 1992 chevy lumina can not get piston push in on calibers
Saturday, May 30th, 2009 AT 10:00 PM
BILLYMAC
MECHANIC
Hi, this car may have screw type pistons. If you look inside the cylinder and you see two holes one on either side of the cylinder they are screw type. If they are use vise grips and c clamp at the same time. If they are not screw type the calipers are seized and need replaced billymac
