1991 Chevy Lumina my wiper motor
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEDOCORLEY19681968
my wipers got stuck up i pushed them down then they started working again. then ater a day or 2 i had to repeat a few times. now they wont come on at all and my fluid wont spray either . totally dead. fuses in glove box are good . whats wrong and if its the motor wheres it located.
Dec 10, 2008 at 1:46 AM
JALOPYPAPA
  • 467 POSTS
the motor is under the cowl at the base of your windshield in front of the steering wheel. Replacing it will require removing the wiper arms and cowl, returning the motor arm manually to the rest position, unplugging the electrical connector and unbolting it the motor from the frame and the wiper linkage. A Haynes or Chilton manual or equivalent contains step-by-step instructions.
Dec 13, 2008 at 1:35 AM
