hi my friend has a chevy lumina with theses codes 15 coolant temp signal low/ 22,tps signal low / 43, esc module or sensor problem / 53, system voltage high/ replaced alternator checked all wiring connection replaced esc module but when i scan car it says 25.5 volts with those codes ched batteryu voltage it was within spec and alt was charging also good the car runs a little rough like if it had afouled plug or timing was a little off..any help would be appreciated i cant sleep at night think and guessing whats wrong plus my buddy thinks the mech tech school i went was a waste of time cause i couldnt figure ths out ..thanks for time and patience guys
Jan 15, 2009 at 5:22 PM
