1991 Chevy Lumina
BLACKKNIGHT831
  • 1991 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 286,421 MILES
I have a problem eith my car shutting off going down the road. But it will start right back up. Then other times the check engine light will come on and run like CRAP. Then the light will go off and run fine until the next time it does it. I have changed the fuel pump and it still does it. I have also changed the well I dont remember what its called but it goes under the packs under where the plug wires goes in to the engine. Not on the side that has the spark plugs.
Monday, August 30th, 2010 AT 11:11 PM
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
Monday, August 30th, 2010 AT 11:28 PM
