1990 Chevy Lumina fans and starter
DAVE101101
  • 1990 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 115,000 MILES
When I go to start my car I have to move the negative terminal to get it started also sometimes all my lights and radio come on but the car wont turn over, and I recently figured out that my fans are not moving but my bels still work, what is my problem and could these problems be related to each other, how do I fix it thank you
Friday, October 24th, 2008 AT 9:28 PM
JNOVACK
  • 723 POSTS
Replace the ground (negative) cable first then we can go from there please get back to me
Friday, October 24th, 2008 AT 9:35 PM
DAVE101101
I already replaced the ground wire
Sunday, October 26th, 2008 AT 10:25 AM
JNOVACK
  • 723 POSTS
Ok you replaced the neg. Cable make sure all connections are tight also have battery tested it could have bad cell or cells as for the fans remove the fans and with a jumper wires we are going to jump from battery to fan and see if they work if so then there is a bad fan relay
Sunday, October 26th, 2008 AT 6:16 PM
