faulty oil pressure gauge
CHEVROLET IMPALA
RDROBERTS46
When I first start it up the oil pressure gauge is in the normal range (usually). After driving for awhile the oil pressure gauge bottoms out on the low side. It seems I need to replace the oil pressure sensor (or something like that). Any suggestions?
Randy
Jan 4, 2006 at 12:57 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Your oil pump pick up is plugged, remove the oil pan to clean and reassemble.
Jan 4, 2006 at 2:55 PM
